PTH03010Y,PTH05010Y,PTH12010Y,
消耗积分:2 | 格式:rar | 大小:773 | 2010-11-16
敷衍作笑谈
分享资料个
The PTHxx010Y are a series of ready-to-use switching regulator modules from Texas Instruments designed specifically for bus termination in DDR and QDR memory applications. Operating from either a 3.3-V, 5-V or 12-V input, the modules generate a VTT output that will source or sink up to 15 A of current (12 A for 12-V input) to accurately track their VREF input. VTT is the required bus termination supply voltage, and VREF is the reference voltage for the memory and chipset bus receiver comparators. VREF is usually set to half the VDDQ power supply voltage.
Both the PTHxx010Y series employs an actively switched synchronous rectifier output to provide state-of-the-art stepdown switching conversion. The products are small in size (1.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
