PTH03000W,pdf(6 A, 3.3-V Input
消耗积分:2 | 格式:rar | 大小:375 | 2010-11-16
分享资料个
The PTH03000 series of non-isolated power modules are small in size and high on performance. Using double-sided surface mount construction and synchronous rectification technology, these regulators deliver up to 6 A of output current while occupying a PCB area of about half the size of a standard postage stamp. They are an ideal choice for applications where space, performance and cost are important design constraints.
This series operates from an input voltage of 3.3-V to provide step-down power conversion to any output voltage over the range, 0.9 V to 2.5 V. The output voltage of the PTH03000W is set within this range using a single resistor.
Operating features include an on/off inhibit, output voltage adjust (trim), an output current limit, and over-temperature protection.
评论(0)
发评论
下载排行榜
