ISL90840 pdf datasheet (Quad D
消耗积分:2 | 格式:rar | 大小:666 | 2009-01-10
韩刚龙
分享资料个
The ISL90840 integrates four digitally controlled
potentiometers (XDCP) on a monolithic CMOS integrated
circuit.
The digitally controlled potentiometers are implemented with
a combination of resistor elements and CMOS switches. The
position of the wipers are controlled by the user through the
I2C bus interface. Each potentiometer has an associated
volatile Wiper Register (WR) that can be directly written to
and read by the user. The contents of the WR controls the
position of the wiper. When powered on the ISL90810’s
wiper will always commence at mid-scale (128 tap position).
The DCPs can be used as three-terminal potentiometers or
as two-terminal variable resistors in a wide variety of
applications including control, parameter adjustments, and
signal processing.
评论(0)
发评论
下载排行榜
