ISL54220 pdf datasheet (High-S
消耗积分:3 | 格式:rar | 大小:555 | 2009-01-17
笑尽往事
分享资料个
The Intersil ISL54220 is a single supply dual 2:1 multiplexer
that can operate from a single 2.7V to 5.5V supply. It contains
two SPDT (Single Pole/Double Throw) switches configured as
a DPDT. The part was designed for switching or routing of
USB High-Speed signals and/or USB Full-speed signals in
portable battery powered products.
The 6.7Ω switches can swing rai-to-rail and were specifically
designed to pass USB full speed data signals that range from
0V to 3.3V and USB high speed data signals that range from
0V to 400mV. They have high bandwidth and low capacitance
to pass USB high speed data signals with minimal distortion.
The part can be used in Personal Media Players and other
portable battery powered devices that need to route USB
high-speed signals or full-speed signals to different
transceiver sections of the device while connected to a single
USB host (computer).
评论(0)
发评论
下载排行榜
