ISL22313 pdf datasheet (Low No
消耗积分:3 | 格式:rar | 大小:444 | 2009-03-05
王平
分享资料个
The ISL22313 integrates a single digitally controlled
potentiometer (DCP), control logic and non-volatile memory
on a monolithic CMOS integrated circuit.
The digitally controlled potentiometer is implemented with a
combination of resistor elements and CMOS switches. The
position of the wipers are controlled by the user through the
I2C bus interface. The potentiometer has an associated
volatile Wiper Register (WR) and a non-volatile Initial Value
Register (IVR) that can be directly written to and read by the
user. The contents of the WR control the position of the
wiper. At power up the device recalls the contents of the
DCP’s IVR to the WR.
The ISL22313 also has 14 general purpose non-volatile
registers that can be used as storage of lookup table for
multiple wiper position or any other valuable information.
The ISL22313 features a dual supply, that is beneficial for
applications requiring a bipolar range for DCP terminals
between V- and VCC.
The DCP can be used as a three-terminal potentiometer or
as a two-terminal variable resistor in a wide variety of
applications including control, parameter adjustments, and
signal processing.
评论(0)
发评论
下载排行榜
