DS1091L时钟发生器数据资料(英文)
消耗积分:0 | 格式:pdf | 大小:438 KB | 2011-10-26
分享资料个
The DS1091L is a low-cost clock generator that is factorytrimmed to output frequencies from 130kHz to 66.6MHzwith a nominal accuracy of ±0.25%. The device can alsoproduce a center- or down-dithered spread-spectrumoutput with pin-selectable dither magnitude and rate.Assembled in an 8-pin μMAX® package, the DS1091Lis designed to operate with a 3.0V to 3.6V power supplyover the automotive temperature range (-40°C to +125°C).
评论(0)
发评论
下载排行榜
