Highly integrated system chips, which combine multiple digital and analog functions into a single package, often require multiple power supplies. Usually the microprocessor’s input/output (I/O) and core voltages are two separate and independent power requirements. A typical contemporary microprocessor’s I/O section usually operates at 3.3 V or 2.5 V, but the core sections operate at 1.8 V, 1.5 V, 1.3 V or lower. Improper supply sequencing can result in device latchup, incorrect device initiation, or degradation of long−term reliability. Considering these issues, it’s important to consider the control of the supply−voltage sequencing to guarantee proper system operation. For example, DSPs and some other multi−voltage processors require their I/O voltage to be present before applying the core voltage.
