ADP1612/ADP1613,pdf datasheet
消耗积分:10 | 格式:rar | 大小:43 | 2009-08-22
贾永世
分享资料个
The ADP1612/ADP1613 are step-up dc-to-dc switching con-verters with an integrated power switch capable of providing an output voltage as high as 20 V. With a package height of less than 1.1 mm, the ADP1612/ADP1613 are optimal for space-constrained applications such as portable devices or thin film transistor (TFT) liquid crystal displays (LCDs).
The ADP1612/ADP1613 operate in current mode pulse-width modulation (PWM) with up to 94% efficiency. Adjustable soft start prevents inrush currents when the part is enabled. The pin-selectable switching frequency and PWM current-mode architecture allow for excellent transient response, easy noise filtering, and the use of small, cost-saving external inductors and capacitors. Other key features include undervoltage lockout (UVLO), thermal shutdown (TSD), and logic controlled enable.
The ADP1612/ADP1613 are available in the lead-free 8-lead MSOP.
评论(0)
发评论
下载排行榜
