TLE4966H pdf datasheet
消耗积分:3 | 格式:rar | 大小:555 | 2008-07-24
李娟
分享资料个
The TLE4966H is an integrated circuit double Hall-effect sensor designed specifically for
highly accurate applications. Precise magnetic switching points and high temperature
stability are achieved by active compensation circuits and chopper techniques on chip.
The TLE4966H provides a speed signal at Q2 for every magnetic pole pair and a direction
information at Q1. The direction output switches 1μs (min.) before the speed output.
评论(0)
发评论
下载排行榜
