SN54LS05, SN54S05, SN7405, SN7
消耗积分:3 | 格式:rar | 大小:695 | 2010-07-13
分享资料个
These devices contain six independent inverters. To perform correctly, the open-collector outputs require pullup resistors. These devices may be connected to other open-collector outputs to implement active-low wired-OR or active-high wire-AND functions. Open-collector devices often are used to generate high VOH levels.
评论(0)
发评论
下载排行榜
