The SN74F543 octal transceiver contains two sets of D-type latches for temporary storage of data flowing in either direction. Separate latch-enable (
or
) and output enable (
or
) inputs are provided for each register to permit independent control in either direction of data flow. The A outputs are characterized to sink 24 mA while the B outputs are characterized to sink 64 mA.
The A-to-B enable (
) input must be low in order to enter data from A or to output data from B. Having
low and
low makes the A-to-B latches transparent; a subsequent low-to-high transition of
puts the A latches in the storage mode. With
and
both low, the 3-state B outputs are active and reflect the data present at the output of the A latches.
