SN54107,SN54LS107A,SN74107,SN7
消耗积分:3 | 格式:rar | 大小:628 | 2010-08-02
laisvl
分享资料个
The '107 contain two independent J-K flip-flops with individual J-K, clock, and direct clear inputs. The '107 is a positive pulse-triggered flip-flop. The J-K input data is loaded into the master while the clock is high and transferred to the slave and the outputs on the high-to-low clock transition. For these devices the J and K inputs must be stable while the clock is high.
The 'LS107A contain two independent negative-edge-triggered flip-flops. The J and K inputs must be stable prior to the high-to-low clock transition for predictable operation. When the clear is low, it overrides the clock and data inputs forcing the Q output low and the Q\ output high.
The SN54107 and the SN54LS107A are characterized for operation over the full military temperature range of -55°C to 125°C.
评论(0)
发评论
下载排行榜
