TUSB6020,pdf(USB 2.0 High-Spee
消耗积分:5 | 格式:rar | 大小:323 | 2010-09-09
分享资料个
特性
  • USB On-the-Go (OTG) Controller Core
    • Uses Mentor Graphics USB 2.0 OTG Core
    • Dual-Role Controller Can Operate Either as a Function Controller for a USB Peripheral or as the Host/Peripheral in Point-to-Point or Multipoint Communications With Other USB Functions
    • Compliant With the USB 2.0 Standard for High-Speed (480-Mbps) Functions and With OTG Supplement to USB 2.0 Specification
    • Supports OTG Communications With One or More High-, Full-, or Low-Speed Devices
    • Supports Session Request Protocol (SRP) and Host Negotiation Protocol (HNP)
    • Supports Suspend-and-Resume Signaling
    • Configurable for up to 4 Transmit Endpoints or up to 4 Receive Endpoints
    • Configurable FIFOs, Including the Option of Dynamic FIFO Sizing
    • 16k-Byte RAM for USB Endpoint FIFO Shared by USB In/Out Endpoints
    • Support for External Direct Memory Access (DMA) to FIFOs
    • Soft Connect/Disconnect Option
    • Performs All Transaction Scheduling in Hardware
  • System Control Module
    • Controls Clock and Reset Generation and Distribution
    • Controls and Observes Device Power States
    • Supports External Power Management
  • Integrated USB 2.0 OTG PHY
    • Fully Compliant with USB 2.0 Standard and USB 2.0 Transceiver Macrocell Interface (UTMI) Revision 1.05
    • Optimized One-Port Operation at Low Speed (1.5 Mbps), Full Speed (12 Mbps), and High Speed (480 Mbps)
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
