TPS62600,TPS62601,pdf(500mA, 6
消耗积分:5 | 格式:rar | 大小:322 | 2010-10-04
李杰
分享资料个
The TPS6260x device is a high-frequency synchronous step-downdc/dc converter optimized for battery-powered portable applications. Intended for low-power applications, the TPS6260x supports up to 500mA load current, and allows the use of low-cost chip inductor and capacitors.
With a wide input voltage range of 2.3V to 5.5V, the device supports applications powered by Li-Ion batteries with extended voltage range. Different fixed voltage output versions are available from 1V to 2.5V.
The TPS6260x operates at a regulated 6-MHz switching frequency and enters the power-save mode operation at light load currents to maintain high efficiency over the entire load current range.
The PFM mode extends the battery life by reducing the quiescent current to 30µA (typ) during light load and standby operation.
评论(0)
发评论
下载排行榜
