TPS3808G01-Q1,pdf(Low-Quiescen
消耗积分:2 | 格式:rar | 大小:981 | 2010-10-24
久醉不醒
分享资料个
The TPS3808 microprocessor supervisory circuits monitor system voltages from 0.4 V to 5 V, asserting an open-drain RESET signal when the SENSE voltage drops below a preset threshold or when the manual reset (MR) pin drops to a logic low. The RESET output remains low for the user-adjustable delay time after the SENSE voltage and MR return above their thresholds.
The TPS3808 uses a precision reference to achieve 0.5% threshold accuracy for VIT ≤ 3.3 V. The reset delay time can be set to 20 ms by disconnecting the CT pin, 300 ms by connecting the CT pin to VDD using a resistor, or can be user adjusted between 1.25 ms and 10 s by connecting the CT pin to an external capacitor.
评论(0)
发评论
下载排行榜
