TPS65194,pdf(Features)
消耗积分:10 | 格式:rar | 大小:179 | 2010-11-03
overheat
分享资料个
The TPS65194 provides a highly integrated level-shifter solution, primarily intended for TV and monitor applications using GIP technology. The device features a built-in state machine that generates twelve output signals from the five input signals provided by the timing controller (T-CON). In addition, the TPS65194 generates a signal to discharge the display panel during power-down.
Level-shifter outputs are forced to a safe state (VGL) during abnormal panel operation, which is indicated by the T-CON using the EO and GST signals.
评论(0)
发评论
下载排行榜
