PT6931,pdf(25 Watt 5 V Input D
消耗积分:2 | 格式:rar | 大小:180 | 2010-11-18
分享资料个
The PT6930 Excalibur™ series of 8-A dual-output ISRs are designed to power DSP ICs. Both output voltages are independently adjustable with external resistors. The second output may also be set to an alternate lower bus voltage with a simple pin strap. Internal power sequencing of both outputs, during both power-up and power-down, meets the requirements of most DSP chipsets.
评论(0)
发评论
下载排行榜
