AME431B/AME431B-1.24V pdf data
消耗积分:2 | 格式:rar | 大小:333 | 2008-12-01
王涛
分享资料个
The AME431B series ICs are 3-terminal adjustable
shunt regulator with guaranteed temperature stability over
a full operation range. These ICs feature sharp turn-on
characteristics, low temperature coefficient and low output
impendance, which make them ideal substitutes for
Zener diodes in applications such as switching power
supply, charger and other adjustable regulators.
The reference is set to 1.24V for AME431Bxxxxx12.
The output voltage can be set to 1.24V to 16V for
VREF=1.24V part type with two external resistors.
The AME431B precision reference is offered in two reference
tolerance: 0.5% and 1.0%
The 5 main packages have low thermal impendance
which allows operation over a wide range of -40oC to
125oC.
评论(0)
发评论
下载排行榜
