RT9179/DS9179 pdf datasheet (A
消耗积分:3 | 格式:rar | 大小:333 | 2008-12-11
李霞
分享资料个
The RT9179 is a high performance linear voltage regulator
with enable high function and adjustable output with a
1.175V reference voltage. It operates from an input of 3V
to 5.5V and provides output current up to 300mA with two
external resistors to set the output voltage ranges from
1.175V to 4.5V.
The RT9179 has superior regulation over variations in line
and load. Also it provides fast respond to step changes in
load. Other features include over-current and overtemperature
protection. The device has enable pin to reduce
power consumption in shutdown mode.
The devices is available in the popular SOT-23-5 package.
评论(0)
发评论
下载排行榜
