The PCM1715 is a low cost, dual voltage output CMOS digital-to-analog converter. Incorporated into the PCM1715 is a unique multi-level 4th-order deltasigma architecture that eliminates influence from input clock jitter and RF interferance resulting in truly superior performance. The PCM1715 has individual channel attenuator and analog output mode select function which is suitable for CD-ROM application. The on-chip digital filter of the PCM1715 has –62dB stop band attenuation and ±0.008dB ripple in the pass band. The PCM1715 can be used in a wide variety of consumer audio applications. Its low cost, small size, and single +5V operation make it ideal for portable, automotive, CD players, CD-I, CD-ROM, VIDEOCD, tuners, music instruments, and other digital audio applications.
