PCM1718/PCM1718E pdf datasheet
消耗积分:3 | 格式:rar | 大小:333 | 2008-12-19
张丽
分享资料个
The PCM1718 is a complete low cost stereo, audio
digital-to-analog converter, including digital interpolation
filter, 3rd-order delta-sigma DAC, and analog
output amplifiers. PCM1718 is fabricated on a highly
advanced 0.6m CMOS process. PCM1718 accepts 18-
bit normal input data format, or 16- or 18-bit I2S data
format.
The digital filter performs an 8X interpolation function,
as well as special functions such as soft mute and
digital de-emphasis.
PCM1718 is suitable for a wide variety of cost-sensitive
consumer applications where good performance is required.
Its low cost, small size, and single power supply
make it ideal for BS tuners, keyboards, MPEG audio,
PCMCIA audio cards (ZV port), MIDI applications,
and set-top boxes.
评论(0)
发评论
下载排行榜
