ISL59532 pdf datasheet (32x32
消耗积分:5 | 格式:rar | 大小:433 | 2009-01-16
梅利号
分享资料个
The ISL59532 is a 300MHz 32x32 Video Crosspoint Switch.
Each input has an integrated DC-restore clamp and an input
buffer. Each output has a fast On-Screen Display (OSD)
switch (for inserting graphics or other video) and an output
buffer. The switch is non-blocking, so any combination of
inputs to outputs can be chosen, including one channel
driving multiple outputs. The Broadcast Mode directs one
input to all 32 outputs. The output buffers can be individually
controlled through the SPI interface, the gain can be
programmed to x1 or x2, and each output can be placed into
a high impedance mode.
The ISL59532 offers a typical -3dB signal bandwidth of
300MHz. Differential gain of 0.025% and differential phase of
0.05°, along with 0.1dB flatness out to 50MHz, make the
ISL59532 suitable for many video applications.
评论(0)
发评论
下载排行榜
