ISL54221 pdf datasheet (High-S
消耗积分:3 | 格式:rar | 大小:555 | 2009-01-17
分享资料个
The Intersil ISL54221 is a single supply dual 2:1 multiplexer
that can operate from a single 2.7V to 5.5V supply. It contains
two SPDT (Single Pole/Double Throw) switches configured as
a DPDT. The part was designed for switching or routing of
USB High-Speed signals and/or USB Full-speed signals in
portable battery powered products.
The 6.7Ω switches can swing rail to rail and were specifically
designed to pass USB full-speed data signals that range from
0V to 3.3V and USB high-speed data signals that range from
0V to 400mV. They have high bandwidth and low capacitance
to pass USB high-speed data signals with minimal distortion.
The part can be used in Personal Media Players and other
portable battery powered devices that need to route USB
high-speed signals or full-speed signals to different
transceiver sections of the device while connected to a single
USB host (computer).
评论(0)
发评论
下载排行榜
