ISL54208,pdf,datasheet (Low Vo
消耗积分:2 | 格式:rar | 大小:111 | 2009-09-11
建立建利12
分享资料个
The Intersil ISL54208 dual SPDT (Single Pole/Double
Throw) switches combine low distortion audio/video and
accurate USB 2.0 high speed (480Mbps) data signal
switching in the same low voltage device. When operated
with a 2.7V to 3.6V single supply these analog switches
allow audio/video signal swings below-ground, allowing the
use of a common USB and audio/video connector in digital
cameras, camcorders and other portable battery powered
Personal Media Player devices.
The ISL54208 logic control pins are 1.8V logic compatible
which allows control via a standard μcontroller. With a VDD
voltage in the range of 2.7V to 3.6V the IN pin voltage can
exceed the VDD rail allowing for the USB 5V VBUS voltage
from a computer to directly drive the IN pin to switch
between the audio/video and USB signal sources in the
portable device. The part has an enable control pin to open
all the switches and put the part in a low power state.
The ISL54208 is available in a small 10 Ld 2.1mmx1.6mm
ultra-thin μTQFN package and a 10 Ld 3mmx3mm TDFN
package. It operates over a temperature range of -40 to
+85°C.
评论(0)
发评论
下载排行榜
