LM26001B,pdf datasheet (1.5A S
消耗积分:2 | 格式:rar | 大小:557 | 2009-09-29
向日葵的花季
分享资料个
The LM26001B is a switching regulator designed for the high
efficiency requirements of applications with stand-by modes.
The device features a low-current sleep mode to maintain efficiency
under light-load conditions and current-mode control
for accurate regulation over a wide input voltage range. Quiescent
current is reduced to 10 μA typically in shutdown mode
and less than 40 μA in sleep mode. Forced PWM mode is also
available to disable sleep mode.
评论(0)
发评论
下载排行榜
