DS90C031,pdf datasheet (LVDS Q
消耗积分:3 | 格式:rar | 大小:556 | 2009-10-13
ejlwj
分享资料个
The DS90C031 is a quad CMOS differential line driver designed
for applications requiring ultra low power dissipation
and high data rates. The device is designed to support data
rates in excess of 155.5 Mbps (77.7 MHz) utilizing Low Voltage
Differential Signaling (LVDS) technology.
The DS90C031 accepts TTL/CMOS input levels and translates
them to low voltage (350 mV) differential output signals.
In addition the driver supports a TRI-STATE® function
that may be used to disable the output stage, disabling the
load current, and thus dropping the device to an ultra low idle
power state of 11 mW typical.
评论(1)
发评论
TTL转LVDS 2011-09-26
0 回复 举报
我是一家集成电路设计公司,公司开发了好几款TTL转LVDS的芯片,其中有一款跟DS90C031 DS90C032的兼容型号。 收起回复
下载排行榜
全部1条评论
