DS90CR217,pdf datasheet (+3.3V
消耗积分:3 | 格式:rar | 大小:558 | 2009-10-14
分享资料个
The DS90CR217 transmitter converts 21 bits of CMOS/TTL
data into three LVDS (Low Voltage Differential Signaling)
data streams. A phase-locked transmit clock is transmitted in
parallel with the data streams over a fourth LVDS link. Every
cycle of the transmit clock 21 bits of input data are sampled
and transmitted. At a transmit clock frequency of 85 MHz, 21
bits of TTL data are transmitted at a rate of 595 Mbps per
LVDS data channel. Using a 85 MHz clock, the data throughput
is 1.785 Gbit/s (223 Mbytes/sec).
评论(0)
发评论
下载排行榜
