The AAT2786 is a dual output power solution. It includes a 1.5A, 1.4MHz, high-efficiency step-down converter and a high performance 150mA LDO regulator. The stepdown regulator output voltage is adjustable from 0.6V to VIN. The LDO regulator has a factory preset fixed output voltage from 1.2V to 3.3V.
