SN54BCT646, SN74BCT646,PDF(OCT
消耗积分:2 | 格式:rar | 大小:293 | 2010-07-22
王强
分享资料个
These devices consist of bus transceiver circuits, D-type flip-flops, and control circuitry arranged for multiplexed transmission of data directly from the input bus or from the internal registers. Data on the A or B bus is clocked into the registers on the low-to-high transition of the appropriate clock (CLKAB or CLKBA) input. Figure 1 illustrates the four fundamental bus-management functions that can be performed with the ’BCT646 devices.
Output-enable (OE)\ and direction-control (DIR) inputs are provided to control the transceiver functions. In the transceiver mode, data present at the high-impedance port can be stored in either register or in both.
The select-control (SAB and SBA) inputs can multiplex stored and real-time (transparent mode) data.
评论(0)
发评论
下载排行榜
