TPS61300,TPS61301,TPS61305,pdf
消耗积分:2 | 格式:rar | 大小:1577 | 2010-11-02
贾飞小
分享资料个
The TPS6130x device is based on a high-frequency synchronous boost topology with constant current sinks to drive up to three white LEDs in parallel (400mA/800mA/400mA maximum flash current). The extended high-current mode (HC_SEL) allows up to 1025mA/2050mA/1025mA flash current out of the storage capacitor.
The high-capacity storage capacitor on the output of the boost regulator provides the high-peak flash LED current, thereby reducing the peak current demand from the battery to a minimum.
The 2-MHz switching frequency allows the use of small and low profile 2.27micro;H inductors. To optimize overall efficiency, the device operates with a 400mV LED feedback voltage.
The TPS6130x device not only operates as a regulated current source, but also as a standard voltage boost regulator.
评论(0)
发评论
下载排行榜
