ISL3293E, ISL3294E, ISL3295E,
消耗积分:10 | 格式:rar | 大小:333 | 2009-02-07
哈哈哈
分享资料个
The Intersil ISL3293E, ISL3294E, ISL3295E, ISL3296E,ISL3297E, ISL3298E are ±16.5kV HBM ESD Protected (7kV IEC61000 contact), 3.0V to 5.5V powered, single transmitters for balanced communication using the RS-485
and RS-422 standards. These drivers have very low bus
currents (±40mA), so they present less than a “1/8 unit load”
to the RS-485 bus. This allows more than 256 transmitters on
the network without violating the RS-485 specification’s
32 unit load maximum, and without using repeaters.
Hot Plug circuitry ensures that the Tx outputs remain in a
high impedance state while the power supply stabilizes.
The ISL3293E, ISL3294E, ISL3296E, ISL3297E utilize slew
rate limited drivers which reduce EMI, and minimize reflections
from improperly terminated transmission lines, or from
unterminated stubs in multidrop and multipoint applications.
Drivers on the ISL3295E and ISL3298E are not limited, so they can achieve the 20Mbps data rate. All versions are offered in Industrial and Extended Industrial (-40°C to +125°C) temperature ranges.
评论(1)
发评论
lc334 2012-06-01
0 回复 举报
HAO 收起回复
下载排行榜
全部1条评论
