The ISL24026 is a low power, high supply voltage, rail-to-rail input-output dual amplifier. Operating on supplies ranging from 5V to 19V while consuming only 3mA per amplifier, the ISL24026 has a bandwidth of 60MHz (-3dB) and provides common-mode input ability beyond the supply rails, as well as rail-to-rail output capability. This enables the ISL24026 to offer maximum dynamic range at any supply voltage. The ISL24026 also features fast slewing and settling times, as well as a high output drive capability of 65mA (sink and source). These features make the ISL24026 ideal for high speed filtering and signal conditioning applications. Other applications include battery-powered, portable devices and anywhere low power consumption is important. The ISL24026 is available in the 8 Ld HMSOP package, features a standard operational amplifier pinout, and is specified for operation over a temperature range of -40°C to +85°C.
