4-bit Fm+ I2C-bus LED driver PCA9633
消耗积分:1 | 格式:pdf | 大小:227KB | 2014-12-06
冯月芹
分享资料个
The PCA9633 is an I2C-bus controlled 4-bit LED driver optimized for Red/Green/Blue/Amber (RGBA) color mixing applications。Each LED output has its own 8-bit resolution (256 steps) fixed frequency Individual PWM controller that operates at
97 kHz with a duty cycle that is adjustable from 0 % to 99.6 % to allow the LED to be set to a specific brightness value。A fifth 8-bit resolution (256 steps) Group PWM controller has both a fixed frequency of 190 Hz and an adjustable frequency between 24 Hz to once every 10.73 seconds with a duty cycle that is adjustable from 0 % to 99.6 % that is used to either dim or blink all LEDs with the same value。
评论(1)
发评论
746192872 2018-05-16
0 回复 举报
很不错的资料,下来看看,学习学习 收起回复
下载排行榜
全部1条评论
