DS25BR100/DS25BR101,pdf datash
消耗积分:2 | 格式:rar | 大小:550 | 2009-10-13
分享资料个
The DS25BR100 and DS25BR101 are single channel 3.125
Gbps LVDS buffers optimized for high-speed signal transmission
over lossy FR-4 printed circuit board backplanes and
balanced metallic cables. Fully differential signal paths ensure
exceptional signal integrity and noise immunity.
The DS25BR100 and DS25BR101 feature transmit pre-emphasis
(PE) and receive equalization (EQ), making them ideal
for use as a repeater device. Other LVDS devices with similar
IO characteristics include the following products. The
DS25BR120 features four levels of pre-emphasis for use as
an optimized driver device, while the DS25BR110 features
four levels of equalization for use as an optimized receiver
device. The DS25BR150 is a buffer/repeater with the lowest
power consumption and does not feature transmit pre-emphasis
nor receive equalization.
评论(0)
发评论
下载排行榜
