ADM8843,pdf datasheet (Four Wh
消耗积分:3 | 格式:rar | 大小:552 | 2009-10-15
分享资料个
The ADM8843 uses charge pump technology to provide the power to drive up to four LEDs. The LEDs are used for back-lighting a color LCD display that has regulated constant current for uniform brightness intensity. The main display can use up to three LEDs, and the sub display uses one LED. The CTRL1 and CTRL2 digital input control pins control the shutdown opera-tion and the brightness of the main and sub displays.
评论(0)
发评论
下载排行榜
