PCM4202,pdf(PCM4202: High Perf
消耗积分:5 | 格式:rar | 大小:513 | 2010-06-13
鼠爱米
分享资料个
The PCM4202 is a high-performance, stereo audio analog-to-digital (A/D) converter designed for professional and broadcast audio applications. The PCM4202 architecture utilizes a 1-bit delta-sigma modulator per channel, incorporating a novel density modulated dither scheme for improved dynamic performance.
The PCM4202 supports 24-bit linear PCM output data, with sampling frequencies up to 216kHz. The PCM4202 can also be configured to output either 64x or 128x oversampled, 1-bit direct stream digital (DSD) data for each channel. Support for PCM and DSD output formats makes the PCM4202 suitable for a variety of digital audio recording and processing applications.
The PCM4202 includes a flexible audio serial port interface, which supports standard audio data formats.
评论(0)
发评论
下载排行榜
