UCC2888,UCC3888,pdf(Off-line P
消耗积分:2 | 格式:rar | 大小:444 | 2010-09-30
479809
分享资料个
The UCC3888 controller is optimized for use as an off-line, low-power, low-voltage, regulated bias supply. The unique circuit topology utilized in this device can be visualized as two cascaded flyback converters, each operating in the discontinuous mode, both driven from a single external power switch. The significant benefit of this approach is the ability to achieve voltage conversion ratios as high as 400 V to 2.7 V with no transformer and low internal losses.
The control algorithm utilized by the UCC3888 sets the switch on time inversely proportional to the input line voltage and sets the switch off time inversely proportional to the output voltage. This action is automatically controlled by an internal feedback loop and reference.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
