TPS54550,pdf(4.5-V to 20-V Inp
消耗积分:5 | 格式:rar | 大小:930 | 2010-10-03
安德森大
分享资料个
The TPS54550 is a medium output current synchronous buck PWM converter with an integrated high side MOSFET and a gate driver for an low side external MOSFET. Features include a high performance voltage error amplifier that enables maximum performance under transient conditions and flexibility in choosing the output filter inductors and capacitors. The TPS54550 has an under-voltage-lockout circuit to prevent start-up until the input voltage reaches 4.5 V; a slow-start circuit to limit in-rush currents; and a power good output to indicate valid output conditions. The synchronization feature is configurable as either an input or an output for easy 180° out of phase synchronization.
The TPS54550 device is available in a thermally enhanced 16-pin TSSOP (PWP) PowerPAD™ package.
评论(0)
发评论
下载排行榜
