基于扩展卡尔曼滤波器的异步电机转速辨识
消耗积分:10 | 格式:rar | 大小:363 | 2009-07-16
梅利号
分享资料个
在异步电机控制基础上, 利用扩展卡尔曼滤波器将转子转速看成系统的一个状态量,根据定子侧可以测量的电流、电压值, 逐步估计出转子转速, 为研制无速度传感器控制打下基
础。
关键词: 扩展卡尔曼滤波器 转子转速 无速度传感器
Abstract  The rotor speed can be tacken as a state variable of the system by using the Extended Kalman Filter , which based on the vector cont rol of an asynchronous motor. Based on the measured stator current s and stator voltages , we can estimate the rotor speed. It is very useful for us to study the application of the speed sensorless motor cont rol.
Keywords : Extended kalman filter , rotor speed , sensorless
评论(0)
发评论
下载排行榜
