DS90C031B,pdf datasheet (LVDS
消耗积分:3 | 格式:rar | 大小:551 | 2009-10-13
分享资料个
The DS90C031B is a quad CMOS differential line driver
designed for applications requiring ultra low power dissipation
and high data rates. The device is designed to support
data rates in excess of 155.5 Mbps (77.7 MHz) utilizing Low
Voltage Differential Signaling (LVDS) technology.
The DS90C031B accepts TTL/CMOS input levels and translates
them to low voltage (350 mV) differential output signals.
In addition the driver supports a TRI-STATE function
that may be used to disable the output stage, disabling the
load current, and thus dropping the device to an ultra low idle
power state of 11 mW typical.
评论(0)
发评论
下载排行榜
