The MP18024 is a high-frequency, 100V, halfbridge, N-channel, power MOSFET driver. Its lowside and high-side driver channels are independently controlled and matched with less than 5ns in time delay. Under-voltage lockout on both high-side and low-side supplies force their outputs low in case of insufficient supply. The integrated bootstrap diode reduces external component count.
Drives an N-Channel MOSFET Half Bridge 100V VBST Voltage Range On-Chip Bootstrap Diode Typical Propagation Delay of 20ns Gate Drive Matching Of Less Than 5ns Drives A 2.2nf Load with 15nm Rise Time and 12ns Fall Time at12v VDD TTL-Compatible Input Quiescent Current of Less Than 150A UVLO for Both High Side and Low Side SOIC8E Package APPLICATIONS Telecom Half-Bridge Power Supplies Avionics DC-DC Converters Two-Switch Forward Converters Active-Clamp Forward Converters
