CAT25128-128Kb的SPI串行CMOS EEPRO
消耗积分:5 | 格式:rar | 大小:221 | 2010-03-04
分享资料个
The CAT25128 is a 128−Kb Serial CMOS EEPROM device internally organized as 16Kx8 bits. This features a 64−byte page write buffer and supports the Serial Peripheral Interface (SPI) protocol. The device is enabled through a Chip Select (CS) input. In addition, the required bus signals are clock input (SCK), data input (SI) and data output (SO) lines. The HOLD input may be used to pause any serial communication with the CAT25128 device. The device features
software and hardware write protection, including partial as well as full array protection.
评论(0)
发评论
下载排行榜
