TPS65130,TPS65131,pdf(Positive
消耗积分:10 | 格式:rar | 大小:784 | 2010-10-02
哈哈哈
分享资料个
The TPS65130/1 is dual-output dc-dc converter generating a positive output voltage up to 15 V and a negative output voltage down to –15 V with output currents in a 200 mA range in typical applications, depending on input voltage to output voltage ratio. With a total efficiency up to 85% the device is ideal for portable battery powered equipment. The input voltage range of 2.7 V to 5.5 V allows the TPS65130/1 to be directly powered from a Li-Ion battery, from 3 cells NiMH/NiCd or alkaline batteries. The TPS65130/1 comes in a small 4 mm x 4 mm QFN-24 package. Together with a minimum switching frequency of 1.25 MHz it enables designing small power supply applications since it requires only a few small external components.
评论(0)
发评论
下载排行榜
