TPS54377,pdf(1.6 MHz, 3-V to 6
消耗积分:2 | 格式:rar | 大小:840 | 2010-10-03
goodmbby
分享资料个
As a member of the SWIFT™ family of dc/dc regulators, the TPS54377 low-input-voltage high-output-current synchronous-buck PWM converter integrates all required active components. Included on the substrate with the listed features are a true, high performance, voltage error amplifier that provides high performance under transient conditions; an undervoltage-lockout circuit to prevent start-up until the input voltage reaches 3 V; an internally and externally set slow-start circuit to limit in-rush currents; and a power good output useful for processor/logic reset, fault signaling, and supply sequencing.
For reliable power up in output precharge applications, the TPS54377 is designed to only source current during start-up.
评论(0)
发评论
下载排行榜
