TPS727285,pdf(250mA, Ultralow
消耗积分:3 | 格式:rar | 大小:726 | 2010-10-09
分享资料个
The TPS727xx family of low-dropout (LDO) linear regulators are ultralow quiescent current LDOs with excellent line and ultra-fast load transient performance and are designed for power-sensitive applications. The LDO output voltage level is preset by the use of innovative factory EEPROM programming. A precision bandgap and error amplifier provides overall 2% accuracy over load, line, and temperature extremes. The TPS727xx family is available in 1,5mm × 1,5mm SON and wafer chip-scale (WCSP) packages that make it ideal for handheld applications. This family of devices is fully specified over a temperature range of TJ = –40°C to +125°C.
评论(0)
发评论
下载排行榜
