双D触发器—74ls74介绍
消耗积分:0 | 格式:pdf | 大小:74.9 KB | 2011-08-11
分享资料个
The SN74LS74A dual edge-triggered flip-flop utilizes Schottky .TTL circuitry to produce high speed D-type flip-flops. Each flip-flop has individual clear and set inputs, and also complementary Q and Q outputs.Information at input D is transferred to the Q output on the positive-going edge of the clock pulse. Clock triggering occurs at a voltage level of the clock pulse and is not directly related to the transition time of the positive-going pulse. When the clock input is at either the HIGH or the LOW level, the D input signal has no effect.
评论(3)
发评论
z12oo 2013-09-24
1 回复 举报
谢谢楼主 收起回复
ben@ben 2011-08-19
0 回复 举报
感谢楼主分享。 收起回复
全部评论
下载排行榜
全部3条评论
