DS90UR241Q/DS90UR124Q,pdf data
消耗积分:3 | 格式:rar | 大小:556 | 2009-10-14
分享资料个
The DS90UR241/124 Chipset translates a 24-bit parallel bus
into a fully transparent data/control FPD-Link II LVDS serial
stream with embedded clock information. This chipset is ideally
suited for driving graphical data to displays requiring 18-
bit color depth - RGB666 + HS, VS, DE + 3 additional general
purpose data channels. This single serial stream simplifies
transferring a 24-bit bus over PCB traces and cable by eliminating
the skew problems between parallel data and clock
paths. It saves system cost by narrowing data paths that in
turn reduce PCB layers, cable width, and connector size and
pins.
评论(0)
发评论
下载排行榜
