The ES277, a monolithic integrated circuit composed of hall sensor and output coil drivers, is designed for 2-phase DC motor. The high sensitivity of Hall Effect sensor is suitable for motors from mini-type CPU coolers to blowers and DC fans. Typical operation current is 0.3A and operating voltage range is as low as 3.5 volts.
