PTH12020W,PTH12020L,pdf(18 A 1
消耗积分:5 | 格式:rar | 大小:934 | 2010-11-18
杨福林
分享资料个
The PTH12020 series of non-isolatedpower modules offers OEM designers a combination of high performance, small footprint, and industry leading features. As part of a new class of power modules, these products provide designers with the flexibility to power the most complex multi-processor digital systems using off-the-shelf catalog parts.
The series employs double-sided surface mount construction and provides highperformance step-down power conversion for up to 18 A of output current from a 12-V input bus voltage. The output voltage of the W-suffix parts can be set to any value over the range, 1.2 V to 5.5 V. The L-suffix parts have an adjustment range of 0.8 V to 1.8 V. The output voltage is set using a single resistor.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
